drive shaft and rearend
Good looking out,GMCMAN355,I'll pull the nut off and check the splines,only thing left.I will be able to see them once the yoke is off? A two jar puller necessary to pull yoke?CHEVY RULES!
a two jaw puller probably wont be neccessary just tap it away from housing with hammer and walk it from side to side. before you take the nut off though mark it and the pinion stem so that you can get preload back to where it was. also use plenty of threadlock for reassembly
Hi, Men Only Thing I Found Was That The Left Axle Had Spun In The Gear . The Gear Would Not Release From The Axle; I Believe That's The Problem. I Put A Used One In Today(45$ Salvage Yard)know How It Works Tommorrow
