Nope, as far as I know plastic alone was factory.
If you had plastic and clips, then more than likely they had been changed and the PO did not clean the plastic out.
Straight from the factory is plastic only.
The replacement joints come with the clips.
There is no need for clips if the plastic is holding them.
I have a friend who runs a machine shop that specializes in drive-shafts.
For a while several years back, he did a booming business on first time replaced joints.
It seems that the machined out place for the clip on a lot of shafts was not done correctly.
Since GM was not going to use that, they let their vendors get sloppy.
They would chuck the shaft up in a jig, adjust the bearing depth from side to side until it was perfectly lined up, and then inject the plastic.
The shaft ran great until the joints wore out.
Then the hapless owner would press out the joints, install the new ones, with the clips, and the cross would not be centered in the joint, because the recesses for the clips were offset.
After changing them again, and trying everything they could think of, they would bring the shaft to him.
He showed me one. The cross was installed correctly, the clips were seated, and the center of the cross was between 1/8 and 1/4 inch off center.
Maybe more. No way that shaft was ever going to run true.
He would cut off the yoke, weld on a new one, and balance the shaft.
I have not heard about that problem lately, I guess GM got their act together.
J.
