drive shaft on exhaust
'89 bucket
delanco N.J.
i installed a 4" lift on my truck and the kit suggest droping the transfer case down,
i noticed that the front drive shaft is already closer than i would like to the cross piece to the exhaust
if i go any lower i will surely have to modify the exhause crossover
has anyone ever had this problem??
also, in the installation of the lift there were a few parts that i had to cut off or that were lost,,,, nuts and bolts,,,, where can i get replacements for these??
HELP!
Most common nuts and bolts can be replaced at your local hardware store. My local Lowes store has a huge selection of all sorts of fasteners in different grades.
I don't think there's any reason to drop the transfer case down for only a 4" lift. You probably can just leave it, might not even have to mess with your drivelines. I didn't.
He made a good point, in fact, i have about 4" of lift and i have my T-case raised up higher than the factory location with no noticable driveline vibes.
4" you shouldn't worry about droping the t case. But with a 6 I had to. As for the exhaust I had the y pipe routed arround the d shaft for a temporary fix. Headers and true duals will fix that.
