I have a 2-piece driveshaft on my lifted 1991 Crew cab. The rear drive shaft is vibrating a little at the carrier bearing because that is the one place on my driveshaft that has too much of an operating angle. The rest of the u-joint operating angles are good.
I want to put a CV-joint (a.k.a Double Cardan) at the rear driveshaft carrier bearing slip yoke. I do not want to spend thousands of dollars on a complete custom driveshaft because I know the only problem with my driveshaft is at the rear driveshaft carrier bearing.
There seems to be not much choice in building a CV-joint for that area of a 2-piece driveshaft. I did find one possible option at Driveshaft Specialist in Texas (pictured below). I have had a couple of drive line shops tell me it cannot be done. When I ask why?...they cannot come up with a straight answer. It seems like more of an opinion than based on technical reasoning. Any thoughts or solutions to this?
