jtrapani
Need a drive shaft for a stock 74 blazer. I'm either in AZ or western slope CO. Thanks guys.
I have one here...
http://coloradok5.com/forums/showthread.php?t=192525
205 to 12 bolt though, not sure what your running.
Texas. Let me find it, weigh it, and I'll shoot you a pm.
203 ten bolt I believe.... compatible?
If your 74 is stock, should have a 12 bolt. Just count the bolts on the cover. Saw your thread about blowing the d-shaft in 2 lo, so you've got a 203.
Driveshaft differences betwee 203 and 205 - one's shorter than the other. I'm pretty sure that np203 uses the shorter shaft as its a longer case. Might be the other way around.
Hey im in New Castle Co. I have a front and rear for 250/203 12 bolt/44.
