87 K5, 10 bolts. Just got back from the local 4x4 shop after installing a tuff country 2.5” lift, 4.11 gears, ARB lockers and 33x12.50x15 tires. The drive shafts both look like they are now extended about an inch further than stock. Driving above 40mph, let off the gas to coast, and get an sound that I can only compare to a manual trans bad throw out bearing. Definitely something rotating. I’ve put the thing on stands, checked everthing by hand for slop. Seems solid. Is this a by product of the rear drive shaft not being seated as far as it used to be in the transfer case? I seem to remember a similar problem in a CJ7 I had many years ago. This is my first K5, so I’d be interested in your experience. Thank you!
