rickdavis81
Newbie
I boughta m1009 with 4” of lift. Owner said it had just started to vibrate on take off. It vibrates most of the time the faster you go the better. Rear driveshaft had never been extended and was pulled quite a ways out of the tcase. I’m having it lengthened. And it wrecked the rear bushing and seal in the tcase. The tcase sets at 6 deg, pinion at 16 deg and drive shaft has a 23 deg angle. I’m thinking I need to stick the tcase adapter/mount in my mill and get the tcase angle around 14 to 15 deg. Does this sound acceptable?
