Driveline help
53chevy
pitcairn
Im thinking of going with H.A.D for my driveline needs on my k3500 4 door long bed ( dana 60/ 14 bolt). I have about 8 inches of suspension lift. Im going to need a longer front driveshaft due to the magnum box. I also went with the h.a.d emergency brake on the rear of the np205. I know ill need to shorten up the mid shaft and then lengthen the rear driveshaft due to the rear lift. Im thinking of jess's 1 ton front set up and 1410 yoke on the 14 bolt. Is there anything im missing? Thanks
Sounds like a nice truck, where's the pics?
You going to replace that carrier bearing too?
getting a pro/advice on driveshafts is a good idea....do it once and be done with it!
I got 1410's on mine and eliminated the double cardan joints.
I beat the shit out if my 1350s. Why would you want 1410? Seems like an unnecessary expense.
I just went with a 1" drive shaft spacer for the front driveshaft on my truck. I have the same amount (maybe a little more) lift than you do.
he cant do a spacer . he added a range box between the tranny and t-case.
jesse @ h.a.d. knows his stuff.
I called jesse today, he sure knows his stuff. He recommend his 42° front shaft and a 2 piece shaft in the rear, all 1410 throughout. Only down side is the price.
