Driveline length.
scooter122983
Fond du Lac, WI
Does anybody know what the drive line length difference is betweeen a th350 and np203 to a th350 and a np205? Just curious now I may get more involved depending on the answers i get. No questions on why I may think this but just give me the dimensions thanks in advance.
If you dont know then say it. This is the second Forum that I posted this on and so far the general consensus is that either no one cares or no one can answer the question.
dam, don't get your panties in a bunch....you think we have nothing to do but wait on you???
My final answer:
I don't know, I'm at work.
There are two types of TH350s short and long tail shafts. The short came with the 203 the long was the 208/ 205's. depends on what you have. I can't tell you the difference between the two but they should be relatively close within a few inches
My final answer:
Better than no response.
I have a th350/203, but my main question is if i get a th350 w/np205 will my d/shafts work. My current th350 is blown. Just reviewing my options.
I don't have any length measurements for you BUT if you remove a TH350/203 and replace it with a TH350/205 your driveshafts WILL NOT work, the rear shaft will be too short and the front shaft will be too long.
I meant 67-72chevytrucks.com. but thanks 4X4 High for the response. I just wasnt sure if the 205 adapter took up that distance.
