Driveline Question- 1350 CV driveshaft
rescue58
Colorado Springs, CO
Does anyone know of/what factory vehicles came stock with CV drivelines, and if so, preferrably 1350 joint size? I have heard that the rear shaft out of newer Super Dutys does, and may be reasonably affordable compared to having one built.. just weiging some options before I do the slip yoke elim and new shaft for my '91./forums/images/graemlins/hack.gif
Thanks
i am not at the house, but my sd has 1410 at the axles, i believe it has the same at the t-case(no cv).
Oops, my bad. I realize now that it is the front shafts which are 1350 CV. I have to check shaft lengths and such, but even if they are short, it might be cheaper to buy one used, and use that to build a new rear shaft for mine. /forums/images/graemlins/hack.gif
