Most of you seen my straight axled 2003 2500hd chevy Silverado, it was regeared by a local pretty well known shop(even on pirate). It was geared with 5:13 motive gears and a Detroit locker. All new bearings and seals. they also regeared my dana 60 also. I changed the fluids after 500 miles and everything was good. I put about 3500 miles on it after that and still good. One day in town I smell gear oil when I was getting gas, I looked and seen around the pinion all wet. I drove it home about 5 blocks and as drove up the street I heard something like a rock kick up(pinion nut). I stopped at the corner the yoke fell off. The rear of the shaft hit the ground, I looked under, slid the shaft out and stuck it in the truck bed. Locked the hubs in and drove about 100ft to my house. I walked down the alley and picked up the washer and nut. It really didn't vibe or make noise before that is what gets me.
So I removed the cover and the gears looked fine and the oil didn't have metal in it. I put the yoke back on and tightened it. The axle seemed to spin ok and no noise or vibes. Until the last month I can feel after 40 mph the vibe, it gets worse at 60 and calms down after that. So I pulled the shaft today and put new spicer joints in it, dropped it of at a driveline shop and it was out .053. They retubed it and I put it back on, vibes are still there like I did nothing. The slip yoke bushing doesn't seem to have play in the 241, the 241 has the t-case saver also so that shouldn't be the problem.
Can the slip yoke bushing even cause vibes if I cant feel any play..?....the pinion doesn't seem sloppy either....any ideas..?...can pinion bearings do those kind of vibes...?
