right.. but that was my point.... a non cv'd setup with equal bad angles will survive much better with a 1410, whereas a 1310 will be much closer to self-destructing limits.. if your angles are phased within a couple degrees of each other, it shouldn't have vibes, regardless of series..
You're right, in theory (certainly the 1410 would be farther from binding).
(Ryoken I know you know this)
The problem is that regular u-joints vibrate, it's part of how they work: each cap speeds up and slows down as the rotate. The idea is to have the u-joints operating at the same angle such that they speed up and slow down at the same rates and the vibrations cancel each other out.
The problem is this really only works at small operating angles (hence the 3 degrees I mentioned before and why you see OEM cv driveshafts on shorter/steeper driveshafts). Once you're trying to cancel out two joints operating at 20 degrees, it may seem like it works on paper but on a truck it often doesn't.
My theory is that, let's say that a shaft with a joint at each end, with equal 3 deg operating angles, can eliminate 95% of the vibration (the angles might not always be perfect due to flex in springs, trans mounts, etc). It seems nearly vibration free.
Now, with the same setup but 20 deg operating angles, the operating angles may match and the two joints may eliminate 95% of the vibration produced but if the vibration produced at 20 degrees of operating angle is 10 times what it was at 3 degrees, you see 10 times the vibration and now it's very noticeable.
My .02
