Officer_sloppyjoe
Registered Member
I just put a 14b sf that I bought from Fourwheelerjeff and a shackle flip on my blazer. According to the speedometer between 50-75 mph the truck vibrates. speedometer is way off as the truck came with 31" tires and 3.07 now it has 33" and 4.56. I measured the TC angle, driveshaft angle and pinion angle. The pinion points up above the Transfer case and it is the factory driveshaft.
TC= 5.5 deg
DS= 16 deg
Pinion = 20 deg
My question is what degree of shim do I need? 15 degrees seems like a lot.
TC= 5.5 deg
DS= 16 deg
Pinion = 20 deg
Pinion needs to be at or close to the same angle as the TC output shaft for the u-joints to be happy. More work than shims, but that large of shims scare the crap outta me.
