88k5blazin
got an 88 k5 with 12" suspension lift. currently has 14bff and d60 and 2wd sm465. have am getting vibes close and above highway speeds and now am hearing bad ratcheting or spooling noise from detroit locker in rear it sounds like, never heard before when had 6" suspension lift. angle at axle is good, but out the trans not so much. drive shaft angle is 18 degrees. i heard 1350 yokes and joints are good to 20 degrees. main question is how much of spacer can i put to drop trans down without any problems, i have a one inch spacer in now
