Drivers door won't completely shut
I can see it now.
Looks like the door is fine.
Go look at the post on the door jam that the door latches to. Does it have a plastic sleeve covering the metal post?
Compare what you see to the passenger side door, I bet the Drivers Side plastic sleeve has broken off.
adjust the striker on the truck itself. should take about 30seconds
also make sure your door isnt saggy or youll need to replace the door hinge bushings/pins.
