drivers front spring perch
Buy kerts and trim the radius up 1/4in?
Yah, Nothing a few minutes with a grinder cant fix.
Or just weld that up. Im surprised that cracked like that. How hard did you crank down the u bolts?
To torque spec. Might have happened when I caught some air and blew out the front spring bushing, haha. But that was well over a year ago.
Figured it there was an OEM matcematched one why fool with all the extra griding.
I was afraid if I welded it up it would fail again later. Is that not a reasonable concern?
if you clean it up and weld it, I would not be worried about it
But get it clean as possible, good ground, bevel the crack if possible, and burn it in hot.
Summit. Oem Chrysler spring perch. Probable as close as your gonna get
