Doing my rebuild of a M1009 body to civilian it's been so long since I took all the parts out of my donor blazer I can't remember about the driver's side kick panel. I have the plastic panel but my question is: The current vent (manual) that came with the M1009 leaves a hole in the sheet metal of the kick panel area. Do I need now to just cover the whole area with sheet metal to close off the left side?
Also have another question. Where does the metal bracket that supports the seat and key buzzer mount? It is a two hole flat bracket that has a buzzer, a relay, and a flasher on it. I have cruise and that bracket mounts to the passenger side of the steering column support tunnel behind the instrument cluster but I can't figure out where the buzzer bracket mounts. Going by the wiring it seems it would be somewhere around or above the gas pedal. If anyone could take some pictures of the underneath of a dash on a fully equipped model that would help.
Thanks in Advance.
Thanks in Advance.
