86gmcjimmy32
Registered Member
Hey guys I got the cucv 14 bolt and Dana 60 Axles under the k5 but have some questions about driveshaft angles. I’m running a slip yoke eliminator so a cv shaft is in order. I understand that this will require my pinion to be pointed directly at the transfer case or a degree or 2 below. I have the rear all mocked up by eye at the moment and it appears I do have it within that range but how can I use an angle finder to make sure. The transfer case should be at about 0 degrees but how do I know what angle to put the rear pinion to? Does everyone just eyeball these? And how about the front axle pinion angle? The K5 is lifted 7” and this caused the front to point nowhere near the transfer case? Should I just leave it the same so I don’t affect caster? Or should I shim it?
