PsRumors
Ready to order my driveshafts and need some help. Been a while since I dealy with them.
Rear transfercase output is 7 degrees down and the rear axle input is 6 degrees up which cancel each other out. Shaft angle will be about 7 degrees. So no double cardon needed and everthing should be smooth
Here is where I need some help. Front output on transfercase is 6 degrees UP and the front axle input is 6 degrees UP. with a shaft angle of 10 degrees. Will a double cardon (cv) shaft work here? What concerns me is the output of the transfercase being 6 degrees UP.
Any thoughts?
Any thoughts?
