Driveshaft Grinding Crossmember
01mudslinger
GRETNA, VIRGINIA
Was wondering if anyone else has the problem of thier Front Driveshaft Grinding on the Crossmember when going up a hill. Mine does going up hills when the back squats down and the front extends down further.
I have 6" superlift
What can be done to fix the problem?
I have 6" superlift
Rotate your front pinion up or remove the Tcase drop if you installed on with your lift. When you drop the rear of the tcase you raise the front.
Dik
Just a thought, is the crossmember on the right way? By that I mean is the side that has a divet on it under the front out put shaft of the t-case?
Hold my beer & watch this!
Ill have to look tomorrow, i bought it already with the lift on it, so im not sure about the Tranfer case drop, and ill check the crossmember and see if i can figure out what you mean by that, not sure what a divet is, haha. Thanks for the help guys.
There is spot where the output shaft should go that is rounded down. If it is on backwards it will be on the driver side rear of the crossmember.
