Glen1978
Registered Member
Well decided to do a one ton axle swap on my 89 K5. Ok......everything is suppose to work right? NO! Heres what Im running. 14 bolt rear, 56 " spring swap in the rear, zero rate to move axle back one inch to center it up, DIY4x4 shackle flip with 6" shackles. Put the rear driveshaft in with tcase and pinion matching each others angles. Front joint angle is horrible......would probably bind when drooped. Shaft is too short as well.....would probably fall out when drooped. I was under the impression that the rear shaft bolted right in from stock K5.....wrong. So now I need to get a new shaft made. CV looks like the only way to go. I have a NP241 and its a stock slip yoke. Would that be ok for mild trail riding and street duty? Really dont want to spend the coin to put a SYE kit on it. Just need some advice on what to do. Didnt see this coming and pretty bummed out.
