MetalCore_Blazer393
Registered Member
i have a 6inch lift on my 87 k5 and i never really noticed this till a friend pointed it out, my drive shaft is at some seriuous angles and idk how it is even still in the T-case, its got about 5inchs from the top U-joint to the T-case so lie maybe an inch or 2 actually inside of the tcase, anyway whats an easy way to fix this, i was lookin at those double cardan shafts or what ever and that would fix this but there pricey, a longer shaft would help to but then agian price, what i kinda want to know is am i going to have to suck it up and put out for ether of those or what i was thinking is can i take a front drive shaft out of another k5 cause the front ones came with the double cardan cv driveshaft thing and if i can just take the actual shaft part off of it and take just the double cardan part and put it on my rear it would supply the 2-4inchs i need and give me better driveshaft angles, will this work or has anyone tryed this? if not what should i do, any other cheap suggestions are greatly welcomed lol thanks
