I installed a 4" lift on my '88 K5 which led to my driveshaft being angled basically to the sky. I marked where it was, then I disconnected the U-joint bolts and slid it all the way forward, and measured the difference. It came to almost 3", so I subtracted .5" for slop and took it to my local shop to get it lengthened. Well I either measured wrong, or they lengthened too much, because I had a lot of trouble getting it in. It was almost too perfect a length where I had to jack up the truck slightly to get the u-bolts to fit in the rear-end. Is this normal or should there be a little more fore-aft movement where I should be able to slide the DS full forward, then back to install?
If the DS is a hair too long, what's the worst that could happen? Would it put too much pressure potentially on the TC output shaft when the suspension is loaded?
