Now that I'm getting really close to getting the Chalet back together, I need to do something about a reardriveshaft. I'm going from a stock height truck with a th350/np203/12 bolt to a 4-6" lift(6" if you add the springs and blocks, but the camper sag offsets some of that) th350/np205/14bff. np205 is a 1310 fixed yoke right now. I'd like to just order the 1350 flange and cv shaft from HAD, just don't have the cash right now. Plus, I'd like to run the truck for a while to see how things work before I start investing that kind of money in it again.
1. I could probably use my old rear driveshaft, have a shop add some length, and a conversion joint at the 14bff. Probably be the cheapest route, but I worry about the angle. Also, since I'm running 3/4 tons and 37's I'd like a better driveline in the rear. Total cost about $80
2. Could buy one of Jesse's 1350 flanges, find a superduty shaft for $150ish, then pay to have it sized. Total cost around $350
3. Or, I've got a never used front 1310 cv shaft given to me by a buddy who had it built for a k10 project and then didn't use it. Has the flange to mount to a np241. Could buy this flange built by JE Reel for the 205, have this shaft lengthened, run a conversion joint, and when it wears out or goes boom upgrade to one of HAD's 1350 CV's. Total Cost about $200
Kind of like the third option. I've spent a lot more money lately than I wanted, and it seems the best way to start upgrading now, and gives me the option to bolt on a larger shaft down the line as needed. Looking for some input though.
