got a 3" stock dia gm shaft center to center caps 53" center in a 2wd short bed street truck .
did a ls1 6speed swap and was fine . now we did a 2.73 to 4.10 swap on the rear on 28.0" tire dia . it has a vibe at 65-78 mph ish . above 80ish its smoother and no vibes .
the shaft was checked and rebalanced local at a real good shop and 10+ year guy in the shop .
we are thinking the much higher speed of the shaft now has reached the limits of the shaft before it begins to flex like a rubber band .
if we wanted to build a new shaft what would be your ideas and what to look for ? tube dia ? thickness ? stay 3r gm u-joint or go bigger ? steel or swap in aluminum at 300 bucks more than steel .
