RJB44
Hello -
I recently had a friend replace the u-joints on my rear drive shaft on my 1991 Jimmy. I did not drive the truck until the next day, that is when I got about a mile and half down the road from my house when I got this god-awful vibration then the truck started to shutter hard. I pulled over a looked underneath and did not see anything odd. So I put it into drive again a started out slowly, when all of sudden I heard a hard "wrapping" noise, this time I knew it was something big. I got out, looked again underneath, and saw the drive shaft, at the u-joint, separated from the transfer case. The u-joint was loosely sitting in the yoke.
I ended up having the truck flatbed back to my house. My friend said he put the u-joint in correctly, stating it must have been a bad part? I am curious to know what would have caused the u-joint to separate/, I ended replacing both rears the next weekend and can only think maybe it was the C clips were set correctly? I doubt it was a bad part, I think it was not installed correctly.
Feedback Welcome?
RJB44
Feedback Welcome?
RJB44
