My '88 blazer has been out of comission for a while because the rear ten bolt's govlock stripped the teeth off a side gear... swapped in a S.F.14 bolt...and a 4" lift...
now I'm setting up driveshafts and shocks... If i set the rear pinion angle up to run the stock driveshaft, the u-joints are almost running at their max. capacity with the truck on level ground... I don't really feel like paying to have a C.V. shaft made for a slipyoke shaft (np208), and I'm not really ready to swap in a different case with a solid yoke just because I need a C.V. shaft...
My question: I have a couple extra drive shafts... Could i take the C.V. cage off my spare front driveshaft, and put it directly in between the two yokes on the transfer end of my current rear slip shaft? basically replace the top u-joint with a front driveshaft's cage, and 2 new joints?
I know the axle end (single joint) of the front shaft uses a smaller U-joint than the rear driveshaft does, but the joints in the C.V. end of the front shaft appear to be the same size as the rear driveshaft's joints... (I havn't had the chance to take 'em all apart yet)
Has anyone tried this before? Or am I dreaming of this working?
