78GMCJIMMY
I put a 3" Tuff country lift(new springs) on my 78 GMC jimmy about 6 months ago.I replaced the U joints in the rear drive shaft a few months later(they were borderline bad before the lift).The New U joint on the rear shaft is failing at the transfer case after about 2 months of daily driving.Why would the u joint fail so soon?I am only running 33" pro comp X-Terrains.Is there a stronger U joint that will fit a stock driveshaft or should I just go with the Brute force or another heavy duty U joint?Any help is greatly appreciated. thanx David
