Well since the last time I posted I got everything shimmed right. Same angle on pinion and tailshaft, I also put in some new u joints . For the most it's a lot better but still has a little vibration at all speeds under a load. I am thinking that a new driveshaft with a cv joint might be the cure? Would the one in the picture be the one I need? 88 k5 208 and 10 bolt 4" lift.
