Got a few questions..:
How far should the slip yoke at the transfer case stick out..on my '82 K2500,I noticed it has about 3" of the splined portion sticking out of the transfer case..is this normal?..I've never had the shaft out,so I have no idea how long the slip yoke is...I noticed a sticker on the driveshaft tube indicating it was a replacement at one time..(now its so scaly with rust I fear it might twist up like macaroni if I boot it too hard!:eek)..so if I get another shaft I want to get the correct length,if this one is a tad short..the truck is all stock,no lift kit or springs,etc..
Another question :
Has anyone used a master cylinder off a truck with vaccuum power assist brakes on a hydroboost equipped truck??..I have a rebuilt master cylinder I saved off of my '74 GMC K2500 and it looks the same externally,but I dont know if the piston size or where the pushrod seats is the same depth,or if it even has the same bolt spacing (appears it'll bolt on by measuring)..I'd just take it off and try it if I have too,but I was hoping someone here would know off the top of their head if it's swap on or not..if not,a rebuilt master isn't THAT expensive,but being ever so destitute,I'd rather not buy anything I dont have too--at this point even brake fluid is "expensive"..
Another question :
