drivetrain vibration
WJACKSON11X
Madison,GA
at any speed, when i let off the throttle completely, I get a vibration in the rear. If i get back on the throttle, it makes a "clunk" and the vibration stops. right now it is in stock form.
thanks thats what I figured it was. Ill check that when i install all my suspension stuff nxt week.
If the U-joints aren't obviously bad, you should check the rear pinion nut to make sure it hasn't loosened up.
