This came off my 97 dodge ram with a 5" lift. It is the same shape as the stock odge ram pitman arm but the taper is from the bottom on the draglink hole so the draglink come off bottom of arm instead of top. May fit other steering boxes too. There are 32 splines counting the thick splines and the OD of the splines is about 1 3/16" across. Dragling is about 6.5" away from sector shaft center to center. Asking $SOLD shipped USA
