dropped drag link ends?
blazinzuk
Buzzbox voodoo
Rexburg Idaho
Anyone got a part number. I have an after market dropped drag link its the stock style push pull steering.
I was driving up to star valley from idaho falls and it is getting bad at medium speeds I knew it was loose. They aren't the normal drag link ends they look like one ton tie rod ends but not in a situation where I can pull em and go to the parts store.
Would like to get it replaced before I drive back home on friday
Thanks a ton Jess I will update the thread to confirm they are the proper part
Going off of memory, and I haven't dealt with those much, but I'm pretty sure there are different versions. If I remember right, some have L&R ends and some have RH on both sides. And again, IIRC, the Skyjacker ones are about twice the cost of the Rough Country set. And I think Superlift used to make them too.
If I remember right, there are a few different manufacturers (that probably all have their own parts) and at least a couple variations, if you only get one shot at shipping some I hope you're feeling lucky...
Most parts stores have these tie rod ends in stock. I need to fix it his weekend so while my wife is home later on saturday I will pull it apart and go to the parts store
I rarely order stuff like this his doesn't seem to save any money at all. I will get the cheapest possible one. Crossover is on the list just can't swing it right now
