DRW = Dual rear wheel
SRW = single rear wheel
Term for whether a 1-ton is a dually or not. Also use in axle I.D. to tell width. DRW axles are much wider than SRW axles.
My rig is on DRW axles to clean the H-1 beadlocks. on a d60 front it is a hub & rotor swap. Rear axles the tube length & hub is different.
Hi-jack I see on your location you are moving to MO. When you going?
