drw to srw
rob75
Registered Member
santa cruz
im switching my Dana 60f to srw. i found a set of doge hubs with external drive flanges
from what i have read i can use them on a Chevy Dana 60? is there any reason not to use a doge hub? i know the axle will be spinning all the time but it wont see much pavement time
I Don't know of any specific one. Check to make sure your studs are the same size so your lug nuts will be the same front to back.
Only other thing I'd look at is which direction the tie rod comes in from, top or bottom. Wouldn't necessarily prevent me from going for it.
im thinking that if i go this way i can save about 600$ and put it towards a locker
im looking for a cheaper way because i need hubs and lockout hubs
