DTC P0172 and a P0175 codes
6.2 man
Curtis , WA
My 2001 Chev truck with a 350 had a service engine soon light come on My scan tool said the left bank and right bank are too rich . I had read it could be a couple things but not oxygen sensors .I hooked up a gauge and the fuel pressure didn't budge . Any ideas and the difficulty tracking this down . Could my cat be bad ?
2001 truck with a 350? only the vans had 350s in 2001 as far as I know.
Can you look at datastream with your scanner?
My bad you are right it is a van
Ok, so it is a 350. Hmmm... does it have a long crank time when hot? Is the mass air flow sensor clean and have a factory style air filter? What is the fuel presssure? Does your scanner read datastream?
It does not start hard when hot I cleaned the maf I replaced map sensor .Pressure is 62 lbs and doesn't drop after shutdown Has a new fuel pump has a
Maf is cleaned fuel pressure is 62 lbs replaced MAP sensor Starts great even after it is hot and factory air cleaner new filter
