77 casa grande
I'm running dual batteries, one battery for starting, headlights, hvac controls,ect, the other, a deep cycle for the inverter, stereo, cabin lights and, on board air compressor both charged by a single alternator with a isolator.
I have a Viair 480C compressor with a 5 gallon storage tank ,air horn and 150psi pressure switch/relay which is turned on and off with a toggle switch.
My problem is that sometimes I forget to turn on the compresssor on when I get in, result no air horn, or forget to turn it off,letting the compressor cycle on and off somtimes for days at a time.
My question (finally) is can I wire the relay to the igniton switch while still powering the compressor from the deep cycle battery and still keep the two systems seperate? Will there be power bleeding from one side to the other?
Everything is working, should I leave everything alone or am I just asking for trouble?
