dual battery wiring with series option
BUDDY
Midland, TX
OK, so I am getting stuff together for my dual battery set up & I have a perko dual battery switch, a 450 amp Blue Seas ACR, two optima red tops & will soon be acquiring the cable & lugs to hook it all together. As well as the battery trays to mount them onto the framerails in front of the spring hangers.
I am also planning on having a ready welder in my tool kit, which requires 24V minimum to use.
Leads to my question -
Can I wire my dual battery setup to also function as a 24V power source by switching my dual battery switch to off & adding a positive to negative cable with cut-off switch inline to activate the 24V & not have to remove the batteries from their trays?
Basically, I'm lazy & would like to wire this in such a way as to function similar to Ryoken's dual battery setup but also have the added functionality of a 24v system for welding purposes. That way, I don't have to remove the batteries in order to weld.
Just flip the perko switch to off, the series connect switch to on & hook up the leads & go.
Is it that simple or am I missing something.
Thanks in advance,
Buddy
yeah, if you turned the perko switch to off, took off a grd, pos off the other and ran a jumper wire, you'd have a series setup... wouldn't even need a switch in there...
or you could always run a series parallel switch and be real lazy.... :wink1:
honestly off the top of my head, I don't know... it's been a few years since I've played with one... we see em sometimes on the diesel boats... Hateras always used em for their Detroits.. but I see em on windlass systems too on occasion....
I'd have to see one installed (or directions for it) and see how they have/want it wired up to see if it could work in my system.. it COULD, at this point tho I wouldn't be sure HOW unless I researched it a bit...
Here is how it is wired up. Terminal 6 and 7 is the control wire that is usually hooked up the the starter switch but you would have to hook this up to a toggle switch seeing you are not going to be starting your truck with 24 volts. You would still have to retain your original start relay. Battery A 12 V+ is hooked up to Terminal #2. Battery B 12- is hooked up to terminal #1. Terminal #3 gets hooked up through a breaker and then to ground. Terminal #5 gets hooked up to a breaker and then to 12 V+ on Battery B. You shouldn't need anything connected to Terminal #4 as it is used as the control wire to pull in the solenoid on the starter when used as primarily designed. Simple enough?
So, this would connect the batteries in series & then disconnect them so they are both 12V. Correct?
Thanks for the help!
Later,
Buddy
That is correct. These were normally used on some older Diesel engines then ran a 24V starting system and a 12 volt electrical system. I really hated working on those stupid things. I think they are a POS. Luckily most everything I have ever seen now just uses a 12V starting system.
Now, with my limited usage, how do you think this would hold up? I would only use it sparingly because I hope to not be broken on the trail too often. I would obviously want/need to test it out before any trip & then may use it when I'm out, depending on if I'm broke or somebody that i'm with is.
Would you recommend a different way to set this up?
Convenience is a big factor to me, but making sure it works is more important.
Thanks again,
Buddy
