Manually actuated e-brake on one side, regular caliper on the other.Just curious, what's the reason for dual calipers?
A set is on the wish list for the next project.
Manually actuated e-brake on one side, regular caliper on the other.A set is on the wish list for the next project.
how's that work when your axle is locked?
Actually I think it would still work if you were to put the t-case into front wheel driveIt doesn't. You'd have to be using a selectable.
