Dual Rear Wheels with a spacer on the front?
82355
1 ton status
Bradish Nebraska
Does anyone have a picture of the spacers used on a SRW front axle under a DRW truck?
Martin
What application are you talking about? Aftermarket or factory? Older trucks, like the D60 used in Chevy's, had a different hub assembly from the factory between SRW and DRW so technically not a spacer. Most "newer" trucks use a cast spacer like this:
picture.php
and the 88-up bolt on cast spacer will NOT clear the big outside dia of the full float hub anxle flange . and wont clear the dana 60 front hub also .
so you would only be able to possibly try this on a semi float rear but this would be a weak point on a semi float .
The Dodge DRW spacers from the early 2000's are the same way. Just out of curiosity I put one up to the D60/14FF combo on my Blazer and the center hole was quite a bit too small.
