Dual single ended rams
robert97dodge
Lufkin, Tx
I was wandering how is it possible to run dual single ended rams? Do you just put a T in the lines going to the rams? I am thinking about just doing dual rams on my front rockwell.
38377k5 said:
Why would you do that? If you're going to full hydro, why not just use a double ended ram?
Because I cant afford a double ended ram. I would spend around $400 for a double ended ram where as I am spending $150 for 2 single ended rams. I have seen lots of guys do it and it works great.
I'v never seen it. I have a single sided ram that was gonna go on my buggy but i think it's gonna go back on the burb and a double ended one will go on the buggy. theres not much room to mount to singles on there.
Big91RustyBucket said:
No Excuse to not go double ended .....
http://surpluscenter.com/sort.asp?UID=2007072023113056&catname=hydraulic&keyword=HCP1
They also sell steering valves but station has them cheaper.
Also what is station becuase I will be needing a orbital valve. Also is it a good brand? I was thinking about going with PSC or POS for the valve since that is gonna be a important part and I would rather do it right the first time but if the price is right and the quality is good then I am open to other options.
Nevermind I just remember who station is. I have talked to him before and he really knows his stuff. I would of loved to go with his steering but I would of ended up spending $1800 for it plus hoses. I just cant swing that right now. So I am trying to piece together some stuff just so that I can get my rocks under the truck and sell my 10 bolt and 14bolt which I have a guy interested in.
Also what is the actual brand of the rams at that surplus place?
I can't Say what the brand is because I am not sure. When I priced out hydro stuff , station had the best price on steering valve's I could Find. Just make sure you get a cooler , and resovoir. They are very important. But Surplus center was cheapest on ram's. Also If you call station to order the valve tell him the ram size , and he will tell you what cu in you need for what you want to do with it.
