dual steering stabilizer on HD tie rod?
easttxryda
commerce tx
Im running one of the heavy duty tie rod from ord.. (rockrod etc...) is anyone running a dual stabilizer setup with this? I'm curious as to how it works out and what it looks like, also im running a ten bolt, and I already have a single stabilizer setup.
also who makes a setup that works for the tie rod?? i thought ord did but their website is down today or something..
stabilizers are all the same, but you need a new mount for that tierod, which ORD has.
Why do you want dual stabilizers? It's not needed if everything is in check.
When I ordered my HD tie rod from ORD I told them I wanted it to be the stock length so I could use stock tie rods, specifically the left side which has the hole for the stabilizer. So, I'm running an HD tie rod with the stock stabilizer in the stock location with no additional parts required.
One stabilizer should be enough. Some don't run one at all.
Are you currently having a problem? If not the dual stabilizers are pretty much for looks.
I have not run stabilizers on my trucks for years and no problems. Although my Jimmy has one, I will leave it on till I go x over steering
