uglytruk
- Joined
- Oct 24, 2004
- Posts
- 1,329
- Reaction score
- 0
I just put in almost new 4 tube rad in my Blazer, and going up a steep hill, 30 mph, with a 7 1/2 Fisher plow, the engine still overheated.
Otherwise it runs dead on 200. When I stopped at the top of the hill, the fan stopped turning immediately as I turned the engine off. I immediately re-started it, to circulate coolant. Just wanted to check the fan operation.
Can I put on the dual Tstat that my '94 6.5 has?
Any other suggestions? Maybe a deeper blade fan?
Here's the vid...
You can forward to minute 1:40 to avoid some of my banter...
http://www.youtube.com/watch?v=bwZR9U1LPBM
Here's the vid...
, is not going to help the OP with his overheating problem. I've run a dozen 6.2/6.5 trucks in a MULTITUDE of situations, including towing 14K pounds in 90 degree weather behind my K30 crew cab dually. When you work the engine hard, you need more coolant flow.
