VT Dually Dana 70 HD Axle
CUCV2
5/4 ton fun
New England
Going SRW in the crew cab. This axle has 4.10s, is open, only has ~75K miles, and is in good shape. Only $250.
Any trades? Anything you're looking for? How pitted where lower spring clamps were? Is there a tag on front of center? What does it say?
Trades considered. Looking for some rear power crew cab or Suburban doors. Lower spring clamp position appears to be in good shape. It is a 2wd truck and doesn't look like it has seen much winter usage. I wire wheeled it down and took some more pics of the clamp position to give you a better idea of its condition.
Looks good, thank you for doing that. Wheels and tires come with? Barre, VT., correct?
Wheels and tires are just for moving it around only and not included. Will sell them though if you are interested in them. They are fairly new looking.
Do you happen to have any SRW C30 front hubs in good shape?
Sold this one but have another one on my AZ crew cab. Same axle. Dually D70 HD. Just pulled it today.
Thanks, looks like an 84-86 rear, single web. Same as what I've already got. I'm out. Thanks anyway. I was after the double web rear.
Would be interested in the upper and lower Dana 70 HD spring plates, outright, or have 14 bolt plates to exchange. Yes, they are different.
What did the first axle come from? I've been looking for another.
