Dually rear leaf springs, inboard or stock location?
Vombrown
Mountain Man
Great Falls mt
my general thinking is that stock location strings would give a wider stance thus more stability. Mind you I am starting with a non dually 73 3/4 ton truck. I am building a dually for a gin pole setup that I need. I do want to have the tires under the flatbed as much as possible.
just swap on 1ton hangers to the 3/4 ton frame . then use the cab & chassie narrow 14ff drw axle.
then the drw tires might just hang a hair out side of a std width NON drw flatbed .
As Sweet says, it's doable. I did it on a pickup bed, had to tub the wheel wells of course, but it all fit. Look carefully at
Also depends on tire width -- I think mine had 235-85-16's. Coulda been better with a skinnier tire, as mine were awful close.
Anyway, with a flatbed you should be fine. The key is to get the skinny C&C axle (or you can convert a stock one, but it means changing hubs and brake and cutting and rewelding backing plates, which really, REALLY sucks to get them perfectly perpendicular. Voice of experience there.)
-- A
Looks like the viable way to go. C/c axle with outboard springs. Now I just need to find some 1 ton spring hangars and leaf springs.
