Dually rims?
trcooperone
Registered Member
Rexburg, ID
This may be a crazy question, but when you ar poor some times that happens.
I picked up my DRW 60/70 combo yesterday and I was going to try to get H1's but I have no money to get both rims and new tires. So I was curious if I could run my 38/16/13 on the dually rims that came with them.
The rims are stock early 80's dually rims (16x6.25) and from what I have researched they are 6.25" wide. I am currently running the tires above on a 16x7 rim with no issues. I actually really like it because I never pop a bead.
I am aware of the lugs and hub sticking out but after some tire buldge I don't think it would be to bad considering the hub only sticks our 1" anyway.
If anyone knows of someone who had done this or has a picture of it please post up.
Thanks.
The tires will fit the stock wheels, TARussell had the same tires on his dually -
the front should be fine but your problem will be in the rear. I assume you're not running duallies, since you'll only be running the inner wheel (so the front and rear have the same track width) the bearing hub will stick out about 4" beyond the wheel.
