I just put a 203/205 doubler in my ride that i bought from a guy .but I forgot to ask what shifter did what .I has 3 shifters for the transfer case can someone tell me what each one does.
You should be able to look under there and see, but if it's an ORD doubler, then the stick closest to the driver side is the 203, the middle is the rear 205 output, and the right one is the front 205 output.
