I've never dealt with gas charged shocks (i.e. Bilsteins). Is there a trick to installing them at all? I mean, does it take huge force to compress them if they over extend or whatever?
Okay, so this will be fun. One of my lower mounts is tweaked a little so it takes some effort to jam the shock/bushing in. It was a pain with a normal shock. I suppose I should take the time to get it fixed up right before I start wrestling these things.
How tweaked is your lower mount? Mine was tweaked, but i tweaked it back into position with the convenient pry bar ratchet that was in my hand. They bend easily.
It's not real bad. Looks like some previous owner over torqued the shock eye bolt and sort of bowed one side in. I played with bending them in and out a little but they were starting to get far from parallel. With a little more effort I think I can get it right.
I like the idea of trying to compress the suspension before cutting the band. Not sure if I can get enough compression though. The only time I've gotten it close to fully compressed is when ramp testing the opposite corner.
I'm just guessing those shocks might take 100 pounds of force to compress, toward the top. Doesn't that translate to 100 pounds pushing the suspension apart/up, per corner? That's 200 pounds up front, which could counteract a big bumper or winch. Though the bumper does have more leverage, being further out front.
My ORD springs came in tall, so I'm hoping if I get a bumper or winch some day it'll help get it back down. I don't need anything else fighting me the other way.
