Need to replace a radiator and so seems wise to do a full system flush on an old truck. But I'm confused. I understand if I just open the drain on the radiator, that'll leave at least half the total capacity in the block. So if I put the flush stuff in, run, drain, fill with water, run, drain, repeat... when I'm done, now I have a block full of hose water. How do I get it out? It doesn't need to be perfect, but if it's like half the capacity of the system, that's a ton of hard garden hose water in there. The thing I'm not sure about is whether there is a big difference when the lower hose is removed? All the instructions online are a little vague on the details. And I can know the total system capacity, but what I really want to know is how much coolant I'll need with a normal flush. Coolant isn't super cheap these days.
