Dumb sway bar question?
oatsk5
Grand junction CO
Is the sway bar the same for the d60 front and a d44? I dont have the money for a fancy sway bar but tired of the sway I get off and on with my soft springs.
Yes but there are two different diameter ones so when you snag the bushings just measure to be sire they match.
Consider mounting up a rear sway bar. You can use a Helwig or figure out some way to adapt a stock one.
It helped over nothing and was easy to disconnect for off-road use.
i put a sway bar on my plow truck and used ord disconects for the 3" lift correction . i get a lot less sway but also good flex still and i have yet to unhook them .
